Honda C70 No lights
I have a Honda Passport 70 and it has no lights.No brake signals or headlights.Anyone know the problem?
Re: Honda C70 No lights
thats not a moped and there are forums devoted to the C70 -C90's....
but anyway, the C70 needs a (good) battery to run the accessories.. lights, starter motor etc ..
Since you give zero details i'm gonna take a wild guess and say that someone pulled the battery out and just grounded the + battery cable to the frame so the engine will run.
Do not try and start the bike without a battery! You will blow all of your lights out....which iis probably what happened.
Go get a battery, then get out your wallet because those headlamps are not cheap. Check www.dratv.com for parts.
Good Luck,
Matt
Yea- dratv has a replaceable headlamp you can install. It takes $3 bulbs you replace instead of buying a new one everytime time.
Anytime your battery runs low on a C70 passport, you're headlight will blow. It's a problem.
