How do you guys use the choke on a TFR 2003?
After a closer inspection I found that you have to pull it out to enable it (for a while I thought it was back and forth). Now the dumb part is it doesn't stay out if you pull on it and the damn thing is right by the pedals so unless you warp into this weird hernia inducing position there is no way you can hold that choke with one hand and still able to pedal start?
What say you all! <g>
