Re: Possible helicoil
Mike Bartell /
Using a helicoil is pretty easy, if you can drill straight. Follow the directions with the kit and you should be fine.
It is drilling out and tapping the hole to a larger size so a diamond profile spring acts as a holder for the proper sized bolt. You can tap your hole out to the next sized bolt, but then you have to keep track of where that one odd size goes.
