Re: Puch Condenser and Points
Jim Madden /
Positive meter wire to blue wire comming from engine. you'll see it in the terminal block with another blue wire that comes from the body harness that wire goes to the kill switch.Attach meter + wire to engine blue wire not both at once. get a small screw driver and re move wires from terminal block they go to the top terminal right side of block.I'lld actully suggest getting rid of the original terminal block, and solder ring terminals to the wires and replace the block with a modern one from radioshack.Less corrosion build up and brighter lights.Jim
