Re: solex idle lacks "stamina"
Brian Solex /
I looked at your photo (attached) and everything is basically hooked up correctly. The cable could have a little less slack in it, but at the position shown the motor is at idle position. With the motor on the tire and the tire on the floor at idle, is the roller spinning/moving? If it is, then the motor is not all the way down on the tire. If the motor is on the tire and the tire is on the ground and the roller is not spinning and the motor is racing, then I'm lead to believe there is a problem with the clutch, like fuel mixture getting onto the clutch pads through a broken seal on the bearing (not the lipped oil seal that's pressed in to the crankcase, but the shield/seal on the bearing itself.)
ps your Solex looks beautiful.
  solex idle lacks "stamina"Topic by: Nate Rogers Nate Rogers 07/04/05 10:05PM
  Re: solex idle lacks "stamina"Re: Joe Woods Joe Woods 07/04/05 10:57PM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/05/05 01:47AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/05/05 07:49AM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/05/05 07:01PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 12:33AM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/06/05 09:30AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 09:53PM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/05/05 07:22PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 12:43AM
  Re: solex idle lacks "stamina"Re: Joe Woods Joe Woods 07/05/05 11:09AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 12:49AM
  Re: solex idle lacks "stamina"Re: Joe Woods Joe Woods 07/06/05 01:00AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 01:04AM
  Re: solex idle lacks "stamina"Re: Legendre Legendre 07/05/05 12:26PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 12:59AM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/06/05 09:32AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 10:29PM
  Re: solex idle lacks "stamina"Re: Legendre Legendre 07/06/05 10:49AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 10:18PM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/19/05 01:27PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/19/05 03:53PM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/19/05 06:40PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/19/05 07:24PM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/20/05 02:12AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/20/05 03:09AM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/20/05 01:51PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/20/05 06:26PM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/20/05 11:30PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/21/05 12:33AM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/21/05 01:20PM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/21/05 06:13PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/22/05 11:35PM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/22/05 11:46AM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/25/05 12:19AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/25/05 01:14AM
