Re: solex idle lacks "stamina"
Brian Solex /
Zeke,
Hold on now. Are you saying that the spring is on the bottom side of the lever? Look at this picture and see where the spring is hooked up. Is this how yours is hooked up? This is the hook up for the 4600 V2 and V3. The spring should go through a hole in the lever on the carb, not on the hook on the bottom of the lever. Also, the cable should be coming up to the carb pulley from the bottom, not down to it from the top. Again, check the picture and let me know how yours is hooked up. BrianSolex
  solex idle lacks "stamina"Topic by: Nate Rogers Nate Rogers 07/04/05 10:05PM
  Re: solex idle lacks "stamina"Re: Joe Woods Joe Woods 07/04/05 10:57PM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/05/05 01:47AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/05/05 07:49AM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/05/05 07:01PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 12:33AM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/06/05 09:30AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 09:53PM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/05/05 07:22PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 12:43AM
  Re: solex idle lacks "stamina"Re: Joe Woods Joe Woods 07/05/05 11:09AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 12:49AM
  Re: solex idle lacks "stamina"Re: Joe Woods Joe Woods 07/06/05 01:00AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 01:04AM
  Re: solex idle lacks "stamina"Re: Legendre Legendre 07/05/05 12:26PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 12:59AM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/06/05 09:32AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 10:29PM
  Re: solex idle lacks "stamina"Re: Legendre Legendre 07/06/05 10:49AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 10:18PM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/19/05 01:27PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/19/05 03:53PM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/19/05 06:40PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/19/05 07:24PM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/20/05 02:12AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/20/05 03:09AM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/20/05 01:51PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/20/05 06:26PM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/20/05 11:30PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/21/05 12:33AM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/21/05 01:20PM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/21/05 06:13PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/22/05 11:35PM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/22/05 11:46AM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/25/05 12:19AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/25/05 01:14AM
