Re: solex idle lacks "stamina"
Brian Solex /
Zeke,
I don't know of any bolt that goes through the throttle handle. Does it look like something original or something that somebody added?
If you have the throttle handle rolled all the way forward and the throttle barrel is not half way closed, you have to loosen the cable lock on the pulley and reposition the lever/pulley to a position where the barrel is half closed when the throttle handle is rolled all the way forward. When you roll the throttle handle back, the throttle barrel should open all the way. If you don't have the necessary travle in the throttle handle, I've got to think there is a problem with the handle somewhere.
BrianSolex
  solex idle lacks "stamina"Topic by: Nate Rogers Nate Rogers 07/04/05 10:05PM
  Re: solex idle lacks "stamina"Re: Joe Woods Joe Woods 07/04/05 10:57PM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/05/05 01:47AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/05/05 07:49AM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/05/05 07:01PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 12:33AM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/06/05 09:30AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 09:53PM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/05/05 07:22PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 12:43AM
  Re: solex idle lacks "stamina"Re: Joe Woods Joe Woods 07/05/05 11:09AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 12:49AM
  Re: solex idle lacks "stamina"Re: Joe Woods Joe Woods 07/06/05 01:00AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 01:04AM
  Re: solex idle lacks "stamina"Re: Legendre Legendre 07/05/05 12:26PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 12:59AM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/06/05 09:32AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 10:29PM
  Re: solex idle lacks "stamina"Re: Legendre Legendre 07/06/05 10:49AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 10:18PM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/19/05 01:27PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/19/05 03:53PM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/19/05 06:40PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/19/05 07:24PM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/20/05 02:12AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/20/05 03:09AM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/20/05 01:51PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/20/05 06:26PM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/20/05 11:30PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/21/05 12:33AM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/21/05 01:20PM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/21/05 06:13PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/22/05 11:35PM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/22/05 11:46AM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/25/05 12:19AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/25/05 01:14AM
