Re: solex idle lacks "stamina"
Brian Solex /
Zeke,
To access the carb filter on the 4600, remove the air cleaner assembly. You'll see (or should see) a clear/white piece of tube sticking up about 1/2" on the tank side of the carb. Pull that up and out of the carb and you should see that it's a filter about 2 1/2 " long. If you see any particles in the screen part you can try to blow it out with compressed air. It's best just to replace it. I've used carburetor cleaner spray to clean them.
On the 4600 V2 and V3 there is no idle screw. There should be a spring holding the throttle barrel about halfway closed at idle. (Take off the air cleaner assembly. Look down the throat of the carb and move the lever to see the opening and closing of the barrel.) The spring goes from the lever to the casting for the cable. You may have to adjust the position that the throttle cable is locked up at on the pulley. Roll the throttle handle forward and adjust the cable on the pulley until you have the correct idle, 1500 if you're using a tach, by ear/feel otherwise.
BrianSolex
  solex idle lacks "stamina"Topic by: Nate Rogers Nate Rogers 07/04/05 10:05PM
  Re: solex idle lacks "stamina"Re: Joe Woods Joe Woods 07/04/05 10:57PM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/05/05 01:47AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/05/05 07:49AM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/05/05 07:01PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 12:33AM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/06/05 09:30AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 09:53PM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/05/05 07:22PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 12:43AM
  Re: solex idle lacks "stamina"Re: Joe Woods Joe Woods 07/05/05 11:09AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 12:49AM
  Re: solex idle lacks "stamina"Re: Joe Woods Joe Woods 07/06/05 01:00AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 01:04AM
  Re: solex idle lacks "stamina"Re: Legendre Legendre 07/05/05 12:26PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 12:59AM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/06/05 09:32AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 10:29PM
  Re: solex idle lacks "stamina"Re: Legendre Legendre 07/06/05 10:49AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 10:18PM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/19/05 01:27PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/19/05 03:53PM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/19/05 06:40PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/19/05 07:24PM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/20/05 02:12AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/20/05 03:09AM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/20/05 01:51PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/20/05 06:26PM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/20/05 11:30PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/21/05 12:33AM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/21/05 01:20PM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/21/05 06:13PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/22/05 11:35PM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/22/05 11:46AM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/25/05 12:19AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/25/05 01:14AM
