Re: solex idle lacks "stamina"
Joe Woods /
if by a change in mixture you mean the fuel:oil mixture, yes .. that could affect idle.
At idle the air:fuel mix is rich, about 8:1. If the idle situation were already borderline, this rich mix in combination with a richer (more oil) fuel:oil mix could foul the plug. Other influences could be spark plug heat range and plug gap. A cold plug and small gap would be more prone to foul and kill the spark.
Higher humidity and hotter air temps also tend to richen the air:fuel mix. (Water vapor displaces air. Less air per volume of air richens the mix.. Hotter air is less dense and richens the mix for the same reason.. less air per volume..)
So, if you've got a carb with an air mixture screw, try leaning the idle air mixture a bit .. elsewise, if you've added more oil to the fuel mix recently, cut back to where it was.. or try a combination of both.
Adjust oil according to specs or to synthetic oil-mfg recommendations. (Those who've got an oil-pump that can only deliver one set fuel:oil ratio should use only the oil type recommended in the owner's manual.) For conventional oils, no tail-pipe oil drips and little or no smoke is pretty safe.
If a top speed plug chop (use a brand new plug) shows definate sooty residue (unburned fuel residue) on the plug, try a hotter plug. Set the gap to factory specs or a little wider if there's a lot of miles on the engine..
But if the bike's been modified with a different carb or main jet or other changes then all bets are off.. you gotta get down and tune it more carefully.. the general tendancy is to jet too rich where both low RPM performance and peak power suffers.
  solex idle lacks "stamina"Topic by: Nate Rogers Nate Rogers 07/04/05 10:05PM
  Re: solex idle lacks "stamina"Re: Joe Woods Joe Woods 07/04/05 10:57PM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/05/05 01:47AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/05/05 07:49AM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/05/05 07:01PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 12:33AM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/06/05 09:30AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 09:53PM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/05/05 07:22PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 12:43AM
  Re: solex idle lacks "stamina"Re: Joe Woods Joe Woods 07/05/05 11:09AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 12:49AM
  Re: solex idle lacks "stamina"Re: Joe Woods Joe Woods 07/06/05 01:00AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 01:04AM
  Re: solex idle lacks "stamina"Re: Legendre Legendre 07/05/05 12:26PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 12:59AM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/06/05 09:32AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 10:29PM
  Re: solex idle lacks "stamina"Re: Legendre Legendre 07/06/05 10:49AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/06/05 10:18PM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/19/05 01:27PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/19/05 03:53PM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/19/05 06:40PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/19/05 07:24PM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/20/05 02:12AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/20/05 03:09AM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/20/05 01:51PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/20/05 06:26PM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/20/05 11:30PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/21/05 12:33AM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/21/05 01:20PM
  Re: solex idle lacks "stamina"Re: Nate Rogers Nate Rogers 07/21/05 06:13PM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/22/05 11:35PM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/22/05 11:46AM
  Re: solex idle lacks "stamina"Re: Jon Zetterlund Jon Zetterlund 07/25/05 12:19AM
  Re: solex idle lacks "stamina"Re: Brian Solex Brian Solex 07/25/05 01:14AM
