Puch Starter
I just salvaged a 1976 Puch Maxi from the dumpster. Decent shape.
It came with no starter cable. I installed a new starter cable, and cleaned the carb etc.
I am able to spin the motor with the spark plug out using the starter, but once I put the plug in, there doesent seem to be enough "clutch" to grab the flywheel. I am sure the cable is adjusted correctly. What could this be? Is there a starter clutch that needs replacing?
Any help would be appreciated.
Thanks,
Matt
Re: Puch Starter
Didi you check the transmission fluid? It may be full of water which isn't as slippery as Type F ATF, that is what you need in there, drain whatever it is, refill if and try again.
Re: Puch Starter
I replaced the oil with 85 wt gear oil. I read that this will work.
I think the engine is a bit stiff from sitting so long. I am going to dive in and try and get some penetrating oil on the crank.
I noticed that even without the starter engaged, there is a fair amount of resistance on the drive sprocket.
How do I check to see if the starter clutch needs replacing?
Thanks,
Matt
Re: Puch Starter
See Ya Moped Army /
NEVER use 85 wt gear oil in a moped tranny. It takes ATF Type F.
Re: Puch Starter
OOps. I read that you could use that weight oil on the Moped Junkyard page. It has specs for Puch.
Luckilly the bike hasnt run, so I presume I didnt do any damage. I'll drain and refill with ATF Type F fluid.
Not only does the bike have trouble with the starter, but I am getting no juice out of the magneto.
I hooked up a mutimeter, and put one lead(neg) to the head, and tested voltages to the bus bar. No voltage is registering at any of the terminals when I turn it over.
Where should I check next?
I have no way of getting the flywheel off ( I can get the nut off with an impact driver, but I dont have a gear puller.
This bike is in decent shape, and definitely worth salvaging.
Any help.
Re: Puch Starter
Step one is to go HERE and grab all the Puch manuals ..
Re: Puch Starter
hey
check to make sure the decompression valve is not stuck shut. if it doesn*t open it will be real hard to pedal and so
hard to strart. adjust that decomp. cable too
Re: Puch Starter
With only one exception, the Puch engines do not have compression release valves. I think the exception is the Bombardier Puchs.
The 85W gear oil is way too thick, and has the wrong additives for a moped clutch. If I had made this error, I'd drain the gear oil, and maybe flush the transmission with some solvent (like tri-chlor), before refilling with the correct ATF type F.
Hopefully the gear oil did not ruin the clutch(es). Wonder why mopedjunkyard posted that info; everything else I have ever read calls for type F.
