Re: 1979 PA50 II Engine Cleaning
Joe Woods /
"This should be the correct Wiring Diagram":https://www.mopedarmy.com/forums/discuss/download.php?f=6&file=1082480832_honda_pa50_1978_wiring_diagram.jpg since the '78-79-'80 PA50s have no battery.
There's nothing special about reasembly beyond being careful and thorough .. shortcuts turn into longcuts.
It might be wise to put a drop of blue (removable) LocTite on the engine block-to-swingarm mounting nuts/bolts (if you actually removed the engine from the swingarm) since they tend to loosen and fall off and get lost.
I'd caution again about getting and keeping the carb and fuel system absolutely clean.. once that's done the bike will run strong and trouble free. Use fresh gasoline and run the engine at least once every few weeks.. Leave it sitting for a couple months and you'll probably end up dropping the enging and cleaning he carb again.
