Re: new tomos won't start/run
Legendre /
Sounds like most or all of these bikes have carb problems. It's not all that unusual, if they sat around in storage for a year or more. The problem is old gasoline, not the bike itself.
Pull the carb, remove the float bowl. Clean it out in there, and then make sure the main jet is totally clear. Reassemble, put fresh gas in along with a new plug - and try it.
