honda pa50 wont start
we also just pulled this moped out of my grandpas shed and we worked on it but it wont start we do not know how to clean it up without taking the whole engine off to get to the carburator if you any info that might help please email me or reply
thanks a lot
Re: honda pa50 wont start
Throw a couple of ropes or some tie downs over a strong cross beam in your Granpa's shed or barn and attach one one each side of the back of the moped and attach a rope or tie down to each side of the front of the moped. This is so you can lift the frame away from the subframe.
Tie downs work best becuase you can raise and lower them using the mechanism on the tie downs.
Disconnect the rear brake cable from the rear wheel.
Now remove the rear bottom shock bolts on each side of the moped. Remove the one big front bolt in front of the engine area that secures the frame to the sub frame
Now use the tie down or ropes to lift the frame away from the subframe and disconnect the throttle cable from the carb and the wire from the coil to the wiring harness. Be sure and note where all the wires are plugged in so you can put them back in the correct places.
You should now have easy access to the carb.
You will need some penetrating oil and a hand held impact wrench to wack the four phillips head screws that hold the carb to the manifold. It is very difficult to get the screws out without first wacking them to break them loose.
Once you have the carb out, the reed valve is underneath the carb, remove it and inspect it to make sure the reeds are flat and in place and not bent.
Good luck
Zippy, nice description of the easy way to get at that carb. The only thing I would add is once the frame is lifted, you can push the engine to one side or the other and it is quite is to work on straight on, making it easier to get those intake screws out without stripping them!
Good luck!
Also, go to mopedriders.org to download a manual
