HONDA PA50 II 81 Does'nt start
I have a PA50 II and it don't start. It don't make fire and i just change my coil and my breaker contact
please give me trick that i can do I want to run it this summer
Re: HONDA PA50 II 81 Does'nt start
If it does not make spark you will have to go thru the entire ignition system one thing at a time.
Check the contact in the run/stop switch on the right handlebar. They might be corroded.
Check all wires for continuity.
Good luck
