Re: Oil Seals For a Minarelli V1?
Silverfox Sullivan /
Mike:
I just took my V1 apart.
The numbers on the oil seal are as follows:
CORTECO 7
B1B
17-35-8
After measuring them with my calipers and then multiplying by 25.4 the 17-35-8 number appears to be the correct dimensions; 17mm id, 35mm od, and 8mm thick (wide)
You should be able to find these at any bearing supply house.
