Re: Oil Seals For a Minarelli V1?
Mo Peds /
My seals cost about 60ish, I put CR seals in it. Just remove the seal and take to match it up. opeing the case is easy. You could of ball peen them out easy to do. look the performance section about v1's if you want to do tricks to the motor. good luck.
