Re: Oil Seals For a Minarelli V1?
Mike /
If you are inquiring about removal of the clutch then I found the nut to be removed easily by an impact gun.
If you don’t have an impact gun then a set of multi spanner wrenches works ( I use a Craftsman set).
as for the clutch puller I used a standard steering wheel puller set ( I used a Napa set that come with an assortment of metric and standard bolts).
The down side is I need to split the case.
The seals are on the inside.
Thanks Mike
