New Piston
I need to get a new piston for my Jailing NP-50 - does anyone have any idea where I can get one?
New Piston
Steamboat Aka J. R. Stevens /
http://www.rcmoto.com/index.htm E-mail them or pull the piston, take it to a local Honda dealer, it should be the same as a older 50cc honda. At rcmoto you can buy a complete new engine for about $200 or upgrade to 100cc. Question, what happened to the piston? Jim.
Re: New Piston
The piston semi-seized and one of the pins is covered with carbon. I'm a bit aprehensive about removing the rings if I can't find replacement ones and think it might be just as easy [and better off] to get a new one.
Re: New Piston
4-trokes rarely seize unless they are run without oil. If you did run without oil, you may have more problems. Let us know. Jim
Re: New Piston
Lack of oil was not the problem.
