Puch Upgrade: 1sp to 2sp
Matthew Coles /
I converted my 2spd Puch Maxi Sport MKII into a 1spd, and it bolted up fairly easily. There were some slight differences between the E50 and ZA50 though--the exhaust was slightly misaligned where it bolts onto the frame (solved by a little creative drilling), the airbox got jammed between the ignition coil and the carb (but fit, if you smashed it in hard enough), and the middle sidecover screw wasn't aligned with the hole anymore, since it goes through the airbox (solved with a drill and tap).
  Puch Upgrade: 1sp to 2spTopic by: David David 06/30/05 12:32PM
  Re: Puch Upgrade: 1sp to 2spRe: IPOOKforFUN IPOOKforFUN 06/30/05 01:49PM
  Re: Puch Upgrade: 1sp to 2spRe: David David 06/30/05 04:28PM
  Re: Puch Upgrade: 1sp to 2spRe: IPOOKforFUN IPOOKforFUN 06/30/05 05:09PM
  Re: Puch Upgrade: 1sp to 2spRe: Anthony K Anthony K 06/30/05 05:47PM
  Re: Puch Upgrade: 1sp to 2spRe: David David 06/30/05 09:12PM
  Re: Puch Upgrade: 1sp to 2spRe: ilivefaster ilivefaster 06/30/05 10:15PM
  Re: Puch Upgrade: 1sp to 2spRe: A. J. Souza A. J. Souza 07/03/05 06:01PM
  Re: Puch Upgrade: 1sp to 2spRe: ilivefaster ilivefaster 07/03/05 06:46PM
  Re: Puch Upgrade: 1sp to 2spRe: Ray West Ray West 07/03/05 11:09PM
  Puch Upgrade: 1sp to 2spRe: Matthew Coles Matthew Coles 07/03/05 11:47PM
  Re: Puch Upgrade: 1sp to 2spRe: Brett Walker Brett Walker 07/04/05 01:46AM
  Re: Puch Upgrade: 1sp to 2spRe: Brian Mikami Brian Mikami 07/04/05 06:43PM
  Re: Puch Upgrade: 1sp to 2spRe: Sean Taylor 9/18/1971 - 1/14/2007 Sean Taylor 9/18/1971 - 1/14/2007 07/04/05 07:05PM
  Re: Puch Upgrade: 1sp to 2spRe: Brett Walker Brett Walker 07/04/05 07:44PM
  Re: Puch Upgrade: 1sp to 2spRe: Sean Taylor 9/18/1971 - 1/14/2007 Sean Taylor 9/18/1971 - 1/14/2007 07/04/05 11:09PM
  Re: Puch Upgrade: 1sp to 2spRe: Brian Mikami Brian Mikami 07/05/05 12:53AM
  Re: Puch Upgrade: 1sp to 2spRe: Brett Walker Brett Walker 07/05/05 10:32AM
  Re: Puch Upgrade: 1sp to 2spRe: Brian Mikami Brian Mikami 07/05/05 11:58PM
  Re: Puch Upgrade: 1sp to 2spRe: Brett Walker Brett Walker 07/06/05 12:19AM
