Re: Puch Upgrade: 1sp to 2sp
Ray West /
Actually the 1 Speed Magnum was called a Puch Magnum(or Magnum LTD), the two speed was called a Magnum MKII, the Cobra is similar, but different.
As he said they bolt up perfect, though you may have trouble with the intake, on the 2 speed you need a taller intake to clear the cases, and you will also need ot relocate the coil. It is pretty straight forward though.
Wiring should be OK as long as they both have the same number of wires, I think the numbers are 5 or 6 between the different magnetos on Puchs, but it can be done either way.
  Puch Upgrade: 1sp to 2spTopic by: David David 06/30/05 12:32PM
  Re: Puch Upgrade: 1sp to 2spRe: IPOOKforFUN IPOOKforFUN 06/30/05 01:49PM
  Re: Puch Upgrade: 1sp to 2spRe: David David 06/30/05 04:28PM
  Re: Puch Upgrade: 1sp to 2spRe: IPOOKforFUN IPOOKforFUN 06/30/05 05:09PM
  Re: Puch Upgrade: 1sp to 2spRe: Anthony K Anthony K 06/30/05 05:47PM
  Re: Puch Upgrade: 1sp to 2spRe: David David 06/30/05 09:12PM
  Re: Puch Upgrade: 1sp to 2spRe: ilivefaster ilivefaster 06/30/05 10:15PM
  Re: Puch Upgrade: 1sp to 2spRe: A. J. Souza A. J. Souza 07/03/05 06:01PM
  Re: Puch Upgrade: 1sp to 2spRe: ilivefaster ilivefaster 07/03/05 06:46PM
  Re: Puch Upgrade: 1sp to 2spRe: Ray West Ray West 07/03/05 11:09PM
  Puch Upgrade: 1sp to 2spRe: Matthew Coles Matthew Coles 07/03/05 11:47PM
  Re: Puch Upgrade: 1sp to 2spRe: Brett Walker Brett Walker 07/04/05 01:46AM
  Re: Puch Upgrade: 1sp to 2spRe: Brian Mikami Brian Mikami 07/04/05 06:43PM
  Re: Puch Upgrade: 1sp to 2spRe: Sean Taylor 9/18/1971 - 1/14/2007 Sean Taylor 9/18/1971 - 1/14/2007 07/04/05 07:05PM
  Re: Puch Upgrade: 1sp to 2spRe: Brett Walker Brett Walker 07/04/05 07:44PM
  Re: Puch Upgrade: 1sp to 2spRe: Sean Taylor 9/18/1971 - 1/14/2007 Sean Taylor 9/18/1971 - 1/14/2007 07/04/05 11:09PM
  Re: Puch Upgrade: 1sp to 2spRe: Brian Mikami Brian Mikami 07/05/05 12:53AM
  Re: Puch Upgrade: 1sp to 2spRe: Brett Walker Brett Walker 07/05/05 10:32AM
  Re: Puch Upgrade: 1sp to 2spRe: Brian Mikami Brian Mikami 07/05/05 11:58PM
  Re: Puch Upgrade: 1sp to 2spRe: Brett Walker Brett Walker 07/06/05 12:19AM
