Re: Puch Upgrade: 1sp to 2sp
A. J. Souza /
Okay, I will contribut what I know about this, which is incomplete. However, I will say that you can do a search on this because it has been discussed previously.
First, the engines on the Puchs were interchangeable and should bolt right onto the Maxi or Magnum frames.
HOWEVER...while you can use a Magnum top end on a Maxi (and viceversa), the exhaust pipes will NOT work as readily. If you use the Maxi top end, you'll need to use the Maxi exhaust (and viceversa, as I was informed) or you will have to make modifications with welding, drilling etc. Puch did make a one speed Magnum (I think they called it the "Cobra") and if you look at it, it has the Maxi style exhaust rather than the larger Magnum exhaust. If you do a search, I believe Mopedlar got one of these running within the last few months and posted a photo on this website somewhere. He can tell you way more about this than can I.
But at least it is a start.
And no extraneous tuna shots.
  Puch Upgrade: 1sp to 2spTopic by: David David 06/30/05 12:32PM
  Re: Puch Upgrade: 1sp to 2spRe: IPOOKforFUN IPOOKforFUN 06/30/05 01:49PM
  Re: Puch Upgrade: 1sp to 2spRe: David David 06/30/05 04:28PM
  Re: Puch Upgrade: 1sp to 2spRe: IPOOKforFUN IPOOKforFUN 06/30/05 05:09PM
  Re: Puch Upgrade: 1sp to 2spRe: Anthony K Anthony K 06/30/05 05:47PM
  Re: Puch Upgrade: 1sp to 2spRe: David David 06/30/05 09:12PM
  Re: Puch Upgrade: 1sp to 2spRe: ilivefaster ilivefaster 06/30/05 10:15PM
  Re: Puch Upgrade: 1sp to 2spRe: A. J. Souza A. J. Souza 07/03/05 06:01PM
  Re: Puch Upgrade: 1sp to 2spRe: ilivefaster ilivefaster 07/03/05 06:46PM
  Re: Puch Upgrade: 1sp to 2spRe: Ray West Ray West 07/03/05 11:09PM
  Puch Upgrade: 1sp to 2spRe: Matthew Coles Matthew Coles 07/03/05 11:47PM
  Re: Puch Upgrade: 1sp to 2spRe: Brett Walker Brett Walker 07/04/05 01:46AM
  Re: Puch Upgrade: 1sp to 2spRe: Brian Mikami Brian Mikami 07/04/05 06:43PM
  Re: Puch Upgrade: 1sp to 2spRe: Sean Taylor 9/18/1971 - 1/14/2007 Sean Taylor 9/18/1971 - 1/14/2007 07/04/05 07:05PM
  Re: Puch Upgrade: 1sp to 2spRe: Brett Walker Brett Walker 07/04/05 07:44PM
  Re: Puch Upgrade: 1sp to 2spRe: Sean Taylor 9/18/1971 - 1/14/2007 Sean Taylor 9/18/1971 - 1/14/2007 07/04/05 11:09PM
  Re: Puch Upgrade: 1sp to 2spRe: Brian Mikami Brian Mikami 07/05/05 12:53AM
  Re: Puch Upgrade: 1sp to 2spRe: Brett Walker Brett Walker 07/05/05 10:32AM
  Re: Puch Upgrade: 1sp to 2spRe: Brian Mikami Brian Mikami 07/05/05 11:58PM
  Re: Puch Upgrade: 1sp to 2spRe: Brett Walker Brett Walker 07/06/05 12:19AM
