Re: Puch Upgrade: 1sp to 2sp
IPOOKforFUN /
I have done this conversion several times, and basically would not recommend it. You can get a lot more horsepower and speed from going with a speedkit. There are a lot of options available out there for the Puch, so it will pay to look around a bit. I've attached a link for the speedkit that I would recommend in your case. It is a simple bolt on procedure, and this upgrade will not only add class to your machine, but gobs of low end torque and high end tuna packing power.
  Puch Upgrade: 1sp to 2spTopic by: David David 06/30/05 12:32PM
  Re: Puch Upgrade: 1sp to 2spRe: IPOOKforFUN IPOOKforFUN 06/30/05 01:49PM
  Re: Puch Upgrade: 1sp to 2spRe: David David 06/30/05 04:28PM
  Re: Puch Upgrade: 1sp to 2spRe: IPOOKforFUN IPOOKforFUN 06/30/05 05:09PM
  Re: Puch Upgrade: 1sp to 2spRe: Anthony K Anthony K 06/30/05 05:47PM
  Re: Puch Upgrade: 1sp to 2spRe: David David 06/30/05 09:12PM
  Re: Puch Upgrade: 1sp to 2spRe: ilivefaster ilivefaster 06/30/05 10:15PM
  Re: Puch Upgrade: 1sp to 2spRe: A. J. Souza A. J. Souza 07/03/05 06:01PM
  Re: Puch Upgrade: 1sp to 2spRe: ilivefaster ilivefaster 07/03/05 06:46PM
  Re: Puch Upgrade: 1sp to 2spRe: Ray West Ray West 07/03/05 11:09PM
  Puch Upgrade: 1sp to 2spRe: Matthew Coles Matthew Coles 07/03/05 11:47PM
  Re: Puch Upgrade: 1sp to 2spRe: Brett Walker Brett Walker 07/04/05 01:46AM
  Re: Puch Upgrade: 1sp to 2spRe: Brian Mikami Brian Mikami 07/04/05 06:43PM
  Re: Puch Upgrade: 1sp to 2spRe: Sean Taylor 9/18/1971 - 1/14/2007 Sean Taylor 9/18/1971 - 1/14/2007 07/04/05 07:05PM
  Re: Puch Upgrade: 1sp to 2spRe: Brett Walker Brett Walker 07/04/05 07:44PM
  Re: Puch Upgrade: 1sp to 2spRe: Sean Taylor 9/18/1971 - 1/14/2007 Sean Taylor 9/18/1971 - 1/14/2007 07/04/05 11:09PM
  Re: Puch Upgrade: 1sp to 2spRe: Brian Mikami Brian Mikami 07/05/05 12:53AM
  Re: Puch Upgrade: 1sp to 2spRe: Brett Walker Brett Walker 07/05/05 10:32AM
  Re: Puch Upgrade: 1sp to 2spRe: Brian Mikami Brian Mikami 07/05/05 11:58PM
  Re: Puch Upgrade: 1sp to 2spRe: Brett Walker Brett Walker 07/06/05 12:19AM
