Re: inline fuel filter?
james delaney /
MoPedLar showed me a trick that you should do when fitting the filter and hose that will not only prevent kinking but also help trap sediment and, if you have side covers, give you a good visual of the fuel line/filter. Anyway, use a good 6 to 8 inch length of hose going down from the petcock and loop up to the filter. This should be _outside_ of the side cover where you'd see it with the sidecover in place. Then go from the filter outlet back under the sidecover up to the carb.
