intake / carb problem
everytime that i ride for a time like 5-6 min my carb starts to slide off of the intake manifold because of vibration. so i loosen the nut, slide it back up, and tighten it again, but it still does it. any solutions?
Re: intake / carb problem
Well if nothing else will keep you carb from falling off. I woud depending on manifold thickness use a dremmel to machine an ever so slightly deep hole that will accept a flat allen head screw.Then at the corosponding spot on your carb flange drill and tap a hole for said allen screw.HTH.Jim
try usig a lock whasher--or better yet use some locktight--its a liquide like super glue--witch might work just as well...
Don Pflueger /
duct tape it.
lol j/k
