immediate acceleration
what could cause a bike to accelerate immediatly after starting , the throttle cable is set slack, i think it must be a slide problem in the carb or how the force is tranmitted from the cable to slide in the carb. id apreciate any advice on these problems in general
thank you
Re: immediate acceleration
See Ya Moped Army /
The cable might be hanging up inside the outer casing due to rust or kinks in the cable housing. Make sure the cable moves freely within the casing. I replaced a Puch throttle and clutch cable today for the same reason.
