Lightbulb flickering problem
I have a 2003 hero majestic panther and my lightbulb went out so i bought 2 turn signals for a car(if i remember correctly) and it had the same voltage(12v) and looked exactly the same so i bought 2 for 2 dollars.. i got home and i put it in and everything and it works great intill i start using the throttle. When i started using the throttle it flickered. How should i fix this ??
help?
Re: Lightbulb flickering problem
Steamboat Aka J. R. Stevens /
fIRST, INSTALL THE CORRECT BULBS, THEN LET US KNOW WHAT HAPPENS. jIM.
Leon Swarmer /
Hero's run 12 volts?? many run 6.
Does your manual tell you how many watts they should be?
deuch bag i just get the right light bulbs it should work just fine then. u should b fine then bro.
