Re: Honda Express timing question
Jonas Quimby /
Does the engine rev up quickly and the wheel take a very long time to join it, or does the engine just very slowly rev?
If the engine revs much quicker then the wheel, your clutch is worn out.
If on the other hand it bogs down when you give it gas I'd say get the air filter, check that the choke is working properly, clean the carb a second time and then adjust the idle mix/throttle stop screws as per instructions for the Express found on the forums.
