lazer tans fluid
hi all
I have a lazer sport 50 with a minerelli engine. What kiind of trans fluid should i use?
20-O? type f?
shakrah
Creatures of the loin- sf gang
Re: lazer tans fluid
Drain the fluid, fill with 16oz./pint of ND SAE 30 walmart/autoparts store.
Justin Brownell /
www.mopedriders.com
look at the minarelli manuel its helped me out alot
and what I use is ND 20 Non detergent is important because if you use the regular stuff it will foam up inside your gear box or so im told so use ND 20
