Re: tomos wont start
Joe Woods /
only a few things are needed to fire an engine.
The piston must be moving up and down. When it moves upward, whatever is in the space above the piston must be compressed.
There must be some fuel and air in that compressed space.
A spark is needed to ignite that air:fuel mixture.
All these things (spark, compression, fuel) can be easily checked to see if they exist or not. If a engine won't fire, one or more of those things is missing.
This sort of problem has to be carefully approached. Sometimes shortcuts are taken that give false results.
For instance, lets say you don't feel like removing the spark plug to check for spark.. after all, it's a pretty good plug and the bike always ran fine with that plug. So, you just hook another plug to the boot and ground it to the engine and see a spark.. and assume that the plug inside the engine is also firing.. But, that could be a false assumption.
So, be systematic about it.. don't assume anything. Double check everything. If there's compression, fuel and a spark, it will fire.
  tomos wont startTopic by: Ryan K Ryan K 06/20/05 09:26PM
  Re: tomos wont startRe: Saabsonettguy . Saabsonettguy . 06/20/05 10:17PM
  Re: tomos wont startRe: Ryan K Ryan K 06/20/05 11:29PM
  Re: tomos wont startRe: Brock Croy Brock Croy 06/20/05 11:37PM
  Re: tomos wont startRe: Ryan K Ryan K 06/20/05 11:56PM
  Re: tomos wont startRe: Brock Croy Brock Croy 06/21/05 01:12AM
  Re: tomos wont startRe: Ryan K Ryan K 06/21/05 01:01PM
  Re: tomos wont startRe: Joe Woods Joe Woods 06/21/05 01:13PM
  Re: tomos wont startRe: Ryan K Ryan K 06/21/05 01:33PM
  Re: tomos wont startRe: Joe Woods Joe Woods 06/21/05 01:56PM
  Re: tomos wont startRe: Ryan K Ryan K 06/21/05 02:08PM
  Re: tomos wont startRe: Ryan K Ryan K 06/21/05 06:29PM
  Re: tomos wont startRe: Ryan K Ryan K 06/22/05 02:05PM
  Re: tomos wont startRe: Joe Woods Joe Woods 06/22/05 02:27PM
  Re: tomos wont startRe: Ryan K Ryan K 06/22/05 04:02PM
  Re: tomos wont startRe: Joe Woods Joe Woods 06/22/05 04:30PM
  Re: tomos wont startRe: Mike Mike 06/22/05 04:07PM
  Re: tomos wont startRe: Joe Woods Joe Woods 06/22/05 04:32PM
  Re: tomos wont startRe: Joe Woods Joe Woods 06/22/05 04:52PM
  Re: tomos wont startRe: Ryan K Ryan K 06/22/05 07:43PM
  Re: tomos wont startRe: Joe Woods Joe Woods 06/22/05 08:13PM
  Re: tomos wont startRe: Ryan K Ryan K 06/22/05 08:20PM
  Re: tomos wont startRe: Joe Woods Joe Woods 06/22/05 08:33PM
  Re: tomos wont startRe: Ryan K Ryan K 06/22/05 09:58PM
  Re: tomos wont startRe: Joe Woods Joe Woods 06/22/05 10:24PM
  Re: tomos wont startRe: Mike Mike 06/22/05 10:24PM
