Re: tomos wont start
Joe Woods /
spray a little Starter Fluid into the carb intake or spark plug hole.. try to start. If it fires up you've got a fuel delivery problem. If so, check/clean the carb and entire fuel pathway.
if it doesn't fire up either you've either got no spark or not enough compression (need about 80psi to start.. about 120psi to have a healthy engine) Check wiring and switches for no-spark .. use a new plug..
It's rare to have no compresion but since this engine was run without oil for a while, it could be. Use a compression tester. If rings are ok, check for a warped head or some other major leak above the rings.
  tomos wont startTopic by: Ryan K Ryan K 06/20/05 09:26PM
  Re: tomos wont startRe: Saabsonettguy . Saabsonettguy . 06/20/05 10:17PM
  Re: tomos wont startRe: Ryan K Ryan K 06/20/05 11:29PM
  Re: tomos wont startRe: Brock Croy Brock Croy 06/20/05 11:37PM
  Re: tomos wont startRe: Ryan K Ryan K 06/20/05 11:56PM
  Re: tomos wont startRe: Brock Croy Brock Croy 06/21/05 01:12AM
  Re: tomos wont startRe: Ryan K Ryan K 06/21/05 01:01PM
  Re: tomos wont startRe: Joe Woods Joe Woods 06/21/05 01:13PM
  Re: tomos wont startRe: Ryan K Ryan K 06/21/05 01:33PM
  Re: tomos wont startRe: Joe Woods Joe Woods 06/21/05 01:56PM
  Re: tomos wont startRe: Ryan K Ryan K 06/21/05 02:08PM
  Re: tomos wont startRe: Ryan K Ryan K 06/21/05 06:29PM
  Re: tomos wont startRe: Ryan K Ryan K 06/22/05 02:05PM
  Re: tomos wont startRe: Joe Woods Joe Woods 06/22/05 02:27PM
  Re: tomos wont startRe: Ryan K Ryan K 06/22/05 04:02PM
  Re: tomos wont startRe: Joe Woods Joe Woods 06/22/05 04:30PM
  Re: tomos wont startRe: Mike Mike 06/22/05 04:07PM
  Re: tomos wont startRe: Joe Woods Joe Woods 06/22/05 04:32PM
  Re: tomos wont startRe: Joe Woods Joe Woods 06/22/05 04:52PM
  Re: tomos wont startRe: Ryan K Ryan K 06/22/05 07:43PM
  Re: tomos wont startRe: Joe Woods Joe Woods 06/22/05 08:13PM
  Re: tomos wont startRe: Ryan K Ryan K 06/22/05 08:20PM
  Re: tomos wont startRe: Joe Woods Joe Woods 06/22/05 08:33PM
  Re: tomos wont startRe: Ryan K Ryan K 06/22/05 09:58PM
  Re: tomos wont startRe: Joe Woods Joe Woods 06/22/05 10:24PM
  Re: tomos wont startRe: Mike Mike 06/22/05 10:24PM
