Re: Top speed Jerking?
Brian Mikami /
I was 4 stroking with a similar 'brake grab' feel amongst other issues. I suggest you do a run with the air filter OFF. Worked for me, now I a screen filter and it flies...plug color is perfect...not black like it used to look. Metal sounds are bad so you may need a rebuild, but try that first, just for one run and see if it helps.
