Re: Brake light...not bright.
Mike Bartell /
The brake light should be visible at all times, when activated.
Switching the leads may make it brighter- if it's SUPER bright, you will blow the bulb, and you need a resister of soem sort between the lead and the bulb.
I haven't figured out what size of resistor to use, but I'm going to have to soon.
