Crankshaft sealing
Ulf Lindstrm /
Happy friday !
My crankshaft sealing is leaking and making a mess of my ignition-plate.
Does anyone know the measurements of that sealing or know where I can search for that information !?
Have a GREAT weekend !
Ulf Sweden
Re: Crankshaft sealing
Ulf Lindstrm /
...and the moped in question is a Gilera Touring 50 from 1975...I might of course add ! :-)
Most european parts have the metric size on them along with the manfacturers part numbers. If it is leaking the engine/2cycyle will not idle properly either. you will have to remove the seal to check info on it. If you can locate a parts source that has seals for your bike before disassembly would be better.
