Re: design
Jim Madden /
Yeah I will build one but not use it because it makes me nervous to stop the piston to remove nuts ect,But it has worked.I use a spanner wrench used to remove grinding wheels.I bought it at ace hardware for 3.99 it's made of 16 gauge steel about 3/4" wide and 7" long with a shorter piece rivited near the top. The top ends have studs that go into the holes in the flywheels spokes. It can be expanded to reach further apart holes.
It looks like a Y more or less works good to hold flywheel while i remove the nut.Jim
