Re: rope ain't always dope
Jim Madden /
Hi joew,
The only reason I suggest a hard wood dowel is cheapness and above all softer than the aluminum piston another aluminum product against the piston makes me nervous any scratches ect. and more carbon buildup and less compression.if the crank shaft was at an angle wouldn't it be more likely to bend the connecting rod trying to remove that rusted on flywheel nut??? maybe I'm just not thinkin it through right.but anyways if you had it set at TDC you could use it for setting timing ect. have different adjusting holes for different purposes.This from someone who doesn't know much about 2 strokes laugh.never mind.Jim
