Re: rope ain't always dope
Joe Woods /
'search' for several threads about it in this forum.
To prevent the crankshaft from turning so you can remove a nut or whatever, slip a short length of soft rope into the spark plug hole.. this blocks the piston as it rises with a soft pad and prevents the crank from tuning further..
Don't let the rope extend into a port as it may get jammed bad between the port and piston.
