shorting out an engine
how can i short an engine?
i have a 1983 general and i have been having problems getting a spark
i just want to short it out to get spark!
thanks
Kevin
Re: shorting out an engine
Sometimes wires or switches have problems and prevent spark although the magneto can produce spark.
look at THIS thread .. it illustrates the minimum needed connections to test ignition for spark, assuming your bike has a normal points-type iignition and not electronic ignition..
Don Pflueger /
if it has the minerelli engine, use only the red and blue wires from the magneto.
Don Pflueger /
and if your bike has a battery, it must be installed and the tail light bulbs must be good for it to have spark.
thank you vewry much for the help!
i will try that today!
