Re: 80 Puch Maxi compression?
Jason Luther /
it sounds to me that the problem _is_ your starting clutch. without the plug or your thumb covering the hole, the air can escape easily and there is no resistance on the clutch. now when the hole is plugged, the clutch cannot grab hard enough to over-come the compression and it slips. try adjusting the cable tighter.
