I've heard people talk about this too much so I must say...Here is how you make a clutch puller, and I've done the same for a fly wheel. You get a piece of oak (oak flooring as I've used in the pic) and drill a hole big enough for your ratchet to fit through. Then line up the holes on the clutch or flywheel that go around the bolt to hold it in place (same holes that the tool would fit into). Drill some small pilot holes through your board around the big hole where you've marked...then screw some woodscrews through and out the other side. Grind the tips of the screws down with a file or dremel and wha-la. Just place the tips of the ground down screws into the appropriate holes (easy boys) and stick the ratchet through the big hole, hold the board stiff and loosen your nut. I've attached a photo of my clutch puller that I've used a number of times. Simple as that. Lets try to keep the perverted responses to a minimum.
Now would someone sell/trade me an old clogged up biturbo that fits a tomos to use on a funky bike I'm building? Thanks
