Correct plug for Puch Maxi?
Running a 78 Puch Maxi "50cc" with a Proma Exaust and modified carb.
What is the correct plug? Or the original recommended plug for that matter?
The manual is strangely silent on this.
Re: Correct plug for Puch Maxi?
Jason Luther /
ngk b5hs
my manual says NGK B6HS but try out the others and see what you like, the lower the number the hotter the plug and higher the number the cooler the plug
thank you
Jason Luther /
the b5hs (as i understand it) are for the 1.5 and 2 hp models. the b6hs is for the 1 hp model. really i dont think it makes much difference. unless your engine predetonates, then use the cooler plug.
Smitty Smith /
What spark plug did the guy you got your 'ped from put in it??? he may not know what spark plug is best for a moped...he may have put a snowmobile plug in it?
LOL!!! ;^)
Jason Luther /
all 5 mopeds i have bought had the wrong plugs in them.
