Re: Carb Guru Honors, Jawa Division
Silverfox Sullivan /
It sounds o me like your crankshaft oil seals are leaking air into the crankcase. To keep up with the raw air leak you have to artificially choke the carb adding extra gas to whatever is sucked into the crankcase thru the carb.
Has the bike been sitting a long time? Dried out oil seals are a typical result of sitting a long time.
