1977 garelli fuel problem
Troy Weisenmiller /
hi,
im workin on a 77 garelli and its haveing troubles starting.
i know its the gas, cause sprk is good and compression is as well.
i also put a bit of gas into the cylinder head and it will run for 3 secinds and turn off again.
i have cleaned the carb 2 times now and dont know whats it doing that. one thing i do know is the choke is open cause it wont shut right, would that have anything to do with it?
Re: 1977 garelli fuel problem
Leon Swarmer /
The reason the choke is thre is for cold starting the engine. it can make a lot of difference.
Did you also clean the banjo fuel filter on the side of the carb?
Troy Weisenmiller /
troy OP
yes i did clean the fuel filter, and the choke is not engaged, i know it is open so that should be fine, but then again, maybe its closing for soem odd reason when i assemble everything again?
Make sure there is fuel coming out of your petcock. Also a good way to clean carb is strip it down and boil the METAL parts to get all of the gunk out.
Troy Weisenmiller /
troy OP
gas is def comin out of the petcock, first thing i checked, i know better haha
i guess im goin to have to spend like a good couple hours tryin to get the carb clean.
Leon Swarmer /
open is not fine....unless you are going to spray starting fluid through the carb. You need the fuel mix richer as it starts and for the first minute or two.
