Re: can i use a bike tire
Don Pflueger /
nope, and the stem is very important. especially if you need the tube in a rear tire. otherwise the torque from the engine causes the tire to slide around the rim which will rip the valve stem outof the tube, or worse yet, pull the valve stem inside the rim while under full pressure whic makes it impossible to deflate the tube without puncturing it and ruining a good tire and tube, just to remove a tire.
