Honda Express driving me nuts
So i've been working on my honda express for about 3 months now and haven't gotten it to spark once. Here are the things that i have done..
1.) Replaced the points with brand new ones and gapped them correctly
2.) Replaced the Ignition coil
3.)Replaced the spark plug 2 times
4.) Replaced the ignition switch with a new one
I still can't get it running. Everything appears to be in good shape and i am ready to explode. Any help would be great.
thanks
Re: Honda Express driving me nuts
Jonas Quimby /
My guess?
Eather you've got a pinched wire somewhere or you wired the key in wrong.
The wiring of the Express is a little odd, so be sure to grab the wire diagram off the net and check it.
Leon Swarmer /
You haven't mentioned checking the wires to the kill switch,
battery terminals or the fuse off the battery..
You do have a battery in it don't you. You don't want to start it without one.
Leon
Diego perez /
the battery connector thing is all screwed up. I ordered another battery and it didn't have a connector thing on it and i can't find one so i tried to get it on but it just ain't going, so i'm not starting it with a battery i know i can blow the headlight, but i've been working on this bike for 2 years and i haven't made any progress.
Mike Scouty McScoutington /
grab a wiring diagram like they said and also get a meter and check continuity between all connections on the bike. if the problem isnt fixed once the battery issue is taken care of it would be a good bet that the wiring harness is right f'ed up.
Possibly you have a bad coil in the magneto, or the wiring in there is faulty or shorted. don-ohio (:^D
Diego perez /
ok so i studied the wiring diagram.. Now inorder to make it so all of the electricity is just in the coil and the magneto i can't figure this out. There is a green wire and a black wire coming out of the coil which do i unplug? the green is the ground? so i assume the black just goes everywhere else. I'm positive that there is a pinched wire somwhere along the bike. How do i go about just getting this thing running? do i just rewire it myself? thanks.
-diego
Does the bike have a seprate condesor or is it part of the coil if it's seprate I'ld replace it after getting the batt. installed.Jim
