I'm trying to get a motobecane running so I can sell it to my friend, I got the engine running fine, but after about 10 minutes it will die if I slow down and won't start again until it cools off....I don't think oil is the problem because I put the engine on My moped with the Gas that I use in my engine (Mine doesn't over heat)...So what else could be the problem?....the engine is cleanon the inside, there are no boken cooling fins, it's clean on the outside....Any suggestions would be great....
