Re: Puch Maxi Exhaust
Jason Luther /
i wrote that thread. but by the looks of our header, you dont have them. that part (the 'header pipe') is one piece all the way to the engine. there is really no need to remove that, unless to get the cylinder off. if you are concerned about an exhaust blockage, have you looked at the exhaust port on the cylinder for carbon build up? but if your baffles werent too bad, then its probably fine...
