Re: Puch Maxi Exhaust
Jason Luther /
cleaning out the holes is enough, and then just use a piece or wood or something (like a paint stirrer) to scrape any big chunks off of the sides, you dont have to go crazy. by exhaust pipe do you mean the chrome muffler/outer shell thingy? there is a nut in the back that you take off, pull the washer, little tube and then the baffles out. you will probably have to use plyers to get some of the stuff out. oorrr if you have a narrow strudy stick (like a broom handle) you can stick it into the header end of the muffler and hit it on the ground and the baffles will come shooting out. if you have latex gloves, i suggest wearing them. or buy some lava soap :)
