bogging out honda spree
hey, im new here but i guess this is the place to go for some answers that i can not figure out. I picked up an 85 honda spree from a friend and it sat for about a year before i got it. I cleaned everything, new plug, battery and finally got her running. It runs fine until about 19mph and half throttle, anything over that will bog it out any ideas how i can isolate what hte problem is and fix it? ive tried cleaning out the carb 3-4 times...new gas, cleaned the petcock, cut the exhaust off because it was resticting a ton of air so maybe that is something too? does that cause any problems? Well thanks so much i appreciate the help
Re: bogging out honda spree
check the carb and see if it has a mixture screw.play with that and see if it makes any difference
