Re: Akros Tec 50cc went bang
Brian F /
The Akros Tec is a scooter, not a moped. You might have better luck finding people that know about your particular scooter on a scooter forum. This, as the name implies, is a moped forum. :D
It certainly sounds you're talking about the CDI unit. You might want to find someone with a compression tester (or buy one, they're not that expensive), to be sure. Even 20 psi will pass the "finger" compression test, but it's totally insufficient for running most engines.
