rusty fuel tank
Pulled the old PA80 out of the shed this week. My 14 year old wanted to play with it. It had been parked because of a contaminated fuel system which I was aware.
We managed to get the carb and tank off the bike (thanks to the instructions found here)
What I had found was a fuel tank (had plenty of gas) that was full of rust sediment.
I plan to clean the carb and install an in-line filter but does anyone here have any ideas on how to get all that rust sediment out of the tank? Thanks.
Re: rusty fuel tank
Steamboat Aka J. R. Stevens /
Re: rusty fuel tank
I think there are instructions somewhere on this site for doing just that. If the tank is not removable you will have to open the bottom of it and run alot of degreaser and other harsh chemicals to get rid of the inital junk, and then i believe there is some sort of "gas tank repair kit" you can buy which has "stages" of chemicals to put in in order to re-coat the inside and prevent more corrosion.
http://www.prp-porstore.com/page/por15/PROD/TankSealers/FTRK
That should help you out.
hmm i need to think of some clever little catch phrase to write under my posts like everyone else does....
ay carumba...
its so original its genius
Re: rusty fuel tank
I fought this problem and won bigtime. Go to rusteco.com.
Re: rusty fuel tank
the before picture on the left at rusteco.com is definetly not the same object as the after picture below it...The little odds and ends are in different places... there are missing bolts on the first picture....not to mention the "5B" which is missing in the "de-rusted" picture...talk about false advertising?
Re: rusty fuel tank
When I cleaned out my tank last (in like, '99, I'm going to have to do it again) we used a mixture of turpentine and ball bearings. We shook that stuff around to scrape up the rust, and then the turpentine ate away at it. Then, we used some other pretty rough chemicals, and eventually my tank was pretty clean. Installed a new in-line filter and a new in-tank filter, and we were ready to roll again. I'm pretty sure I'll be following the same style procedure this time around, too, considering how well it worked. Hahaha.
Good luck though, half my problems have always been fuel system-related!
